Tirones en R850R
guspster
11 Abr 2009
Hola
Es cierto que la R850R de tirones desagradables en marchas cortas?
Si la tienes bien puesta a punto no tiene por que. También es verdad que algunos modelos como las R 1100/1150 RS tienen el problema innato del "surging"que dicen los ingleses, que son esos tirones que comentas, pero se solucionan con buena puesta a punto, bujías de iridio yun cambio en el CCP..Hay algún post referente a a todo esto, te lo paso en inglés:
[ftp]"Surging" is the major issue for owners of the R1150RS and R1150RT. It is a phenomenon that usually appears at about 2500-3500 rpm under light loads or when cruising with a steady throttle (i.e., around town). It feels like the bike is continually speeding up and slowing down, as if the rider were making tiny throttle adjustments, and it can be very annoying.
It has always been a problem to some extent on oilhead twins, but the larger the engine and the higher the state of tune, the worse it seems to be in practice. Hence the 1150 is worse than the 1100, and the RS/RT are worse than the R/GS and the cruisers.
Some bikes suffer more than others, and it's impossible to predict whether the one you buy will have the problem before you hand over the cash. I would strongly suggest raising the issue with the dealer before purchase, so that you have good grounds for complaint if your bike does it. There's nothing the dealers like more than to say "Sorry, they all do that, Sir". The good news is that there are solutions available if you're unlucky. The links I've included in this section are to what I believe to be pretty definitive information about solutions. There's a lot of less informed speculation around, unfortunately.
Steve Makohin has a good writeup about the possible causes here, although most of the cures are only related to the 1100s (Motronic 2.2).
The BMWRT pages, especially their Forum, have more information than you could possibly want on surging - but in the forums, not all of it is accurate. The usual advice is to perform the valve clearance adjustment and throttle synchronisation extremely carefully, which helps on most bikes, but does not cure all of them. Their FAQ has a lot good information, mainly for 1100s.
In some countries, BMW have approved a different Motronic 2.4 Code Plug (CCP) for the 1150RT/RS, which for many people has reduced the surging to an acceptable level. It doesn't seem to completely remove it. You will often see this referred to on the net as the Olive Green CCP. The stock CCP is pink. The effect is to change the mapping of the fuel injection, presumably to run a richer mixture.
You should be able to get your dealer to do this plug swap for you. If not, you can buy the plug and swap it yourself, or just make up a jumper and connect it as shown here. This is what the green CCP looks like on my bike. The procedure for swapping is to remove the old plug, install the new one, and remove fuse #5 for 30 seconds to clear the memory in the Moronic unit, which will also delete any fault codes it happens to have stored. You then need to turn on the ignition and without starting the engine, twist the throttle wide open. This lets the Motronic unit re-learn the minimum and maximum throttle position sensor readings, and also needs to be done whenever you've had a flat or disconnected battery.
One important thing to note: The coding plugs used, and the effect they have (even the effect of not fitting one) is different between the 1100 and the 1150. So be very careful when following advice on the net about this problem, that the solution you're reading about applies to your bike. Also note that the R, GS, S and cruisers, which have engines in varying different states of tune, use different coloured plugs, and it is unlikely to be safe to use these plugs in the RS or RT.
For a further twist, it appears from reading various French and Belgian riders contributions to the RT forums, that BMW dealers in those countries supply some or all 1150 RS/RTs with the CCP removed altogether. There's no definitive evidence I can find about what this setting actually does, but it's probably safe to assume that it's a different, but richer, setting to that given by the pink plug.
In the UK at least, the green CCP is now also approved by BMW to be fitted in the 1150RS. I've got this on my bike, and it does what other RS and RT owners have reported. The surging is still present, but a lot less noticeable, and rarely enough to be annoying.
[/ftp]
V´ssssssssssssssssssss
yo tengo una R1100R y tambien me los hace, y eso que la puse a punto la semana pasada. Por cierto gracias por el post lo mirare.
Tengo una R850R del 2004 y a mi no me da tirones, en ninguna de las marchas.
Yo tampoco he notado tirones en mi 850, y eso que me toca lididar día a día por ciudad...
La verdad es que antes de comprarla, de tanto leer impresiones negativas a ese respecto por los foros, casi me esperaba que sería como una cafetera... :D
Las impresiones mejoraron justo tras probarla ;)
Un saludo a todos.
La mía de 2007 y he de decir que sí que da tirones en 2ª a punta de gas :-[
hola, buenos días, a mi me da tironcillos, tirones,tirones,no....pero fijarse en esto es como lo de la tos.....mire dr. estoy constipado...atjum,atjum!!...saludos.
¿Tirones?, es normal en un motor Boxer que a bajas revoluciones y en marchas cortas el motor pegue algún tironcillo, la mia lo hace muy levemente, pero nada como para asustarse,...es que el que dice que las Harley suenan como si el motor se fuese a para a relenti...
un saludo.
