close
[TABLE="width: 100%"]
[TR]
[TD]aceite motor recomendado para las que no son lc.[TABLE="width: 100%"]
[TR]
[TD="class: fOne, colspan: 2"]
Aceite de motor[/TD]
[/TR]
[TR]
[TD="class: fOne"]
BMW Motorrad High Performance aceite, SAE 15W-50, API SJ / JASO MA2
[/TD]
[TD="class: fOne"]83 21 2 213 684
[/TD]
[/TR]
[/TABLE]
aceite mot
[/TD]
[/TR]
[/TABLE]
niveles y demas
close
[TR]
[TD][TABLE="width: 100%"]
[TR]
[TD="class: fOne, colspan: 5"]
Datos para el Servicio 0378 - R 1200 R
[/TD]
[/TR]
[TR]
Versión:
[/TD]
[/TR]
[TR]
[TD="class: fOne, colspan: 5"]01.2008
[/TD]
[/TR]
[TR]
[TD="class: fOne, colspan: 5"]11.2007
[/TD]
[/TR]
[/TABLE]
[TR]
[TD="class: fOne"]
Descripción
[/TD]
[TD="class: fOne"]
Condición
[/TD]
[TD="class: fOne"]
UT
[/TD]
[TD="class: fOne"]
Válido
[/TD]
[/TR]
[TR]
[TD="class: fOne, colspan: 4"]
11 - Motor
[/TD]
[/TR]
[TR]
[TD="class: fOne"]número de revoluciones durante el rodaje
[/TD]
[TD="class: fOne"] [/TD]
[TD="class: fOne"]<4000 min-1
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Cantidad de llenado de aceite del motor
[/TD]
[TD="class: fOne"]Con cambio de filtro
[/TD]
[TD="class: fOne"]máx. 4,0 l
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne, colspan: 3"]Agentes de servicio
[/TD]
[/TR]
[TR]
productos recomendados por BMW Motorrad
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Nivel teórico de aceite del motor
[/TD]
[TD="class: fOne"]Entre las marcas MIN y MAX
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
1111 - Bloque motor
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Saliente de la rosca del tirante
[/TD]
[TD="class: fOne"]Cilindro izquierdo, en la válvula de admisión inferior
[/TD]
[TD="class: fOne"]16,5 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
1133 - Basculante / biela de arrastre con cojinete
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Holgura radial del balancín
[/TD]
[TD="class: fOne"]0,05...0,4 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
1134 - Válvulas con resortes
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Holgura de la válvula de admisión
[/TD]
[TD="class: fOne"]con motor frío máx. 35 °C
[/TD]
[TD="class: fOne"]0,15 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Holgura de la válvula de escape
[/TD]
[/TD]
[TD="class: fOne"]0,3 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
1212 - Equipo de encendido, bujías
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Fabricante y designación de las bujías
[/TD]
[TD="class: fOne"]Bosch YR5LDE
NGK DCPR 8 EKC
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Fabricante y designación de las bujías secundarias
[/TD]
NGK DCPR 8 EKC
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
13 - Preparación de combustible y regulación
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Diferencia de presión entre los colectores de admisión
[/TD]
[TD="class: fOne"]con las mariposas cerradas (en ralentí)
[/TD]
[TD="class: fOne"]máx. 25 mbar
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]con las mariposas ligeramente abiertas, 1400...1800 min-1
[/TD]
[TD="class: fOne"]máx. 15 mbar
[/TD]
[/TR]
[TR]
16 - Suministro del combustible
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Cantidad de combustible utilizable
[/TD]
[TD="class: fOne"]aprox. 18 l
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
21 - Embrague
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Nivel de llenado de líquido hidráulico del embrague en el depósito de reserva
[/TD]
[TD="class: fOne"]con forro del embrague nuevo, vehículo recto y manillar enderezado
[/TD]
[TD="class: fOne"]Canto inferior de la ranura del bloqueo de la tapa del depósito
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
Aceite hidráulico (Vitamol V10)
[/TD]
[/TR]
[TR]
23 - Cambio
[/TD]
[/TR]
[TR]
[TD="class: fOne"]
Cantidad de llenado de aceite de cambio
[/TD]
[TD="class: fOne"]hasta el borde inferior de la rosca de la abertura para llenado
[/TD]
[TD="class: fOne"]700 ml
[/TD]
[/TR]
[TR]
Aceite del cambio (Castrol SAF-XO)
[/TD]
[/TR]
[TR]
33 - Eje trasero, propulsión trasera, guiado de la rueda trasera
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Cantidad de llenado de aceite en la propulsión de la rueda trasera
[/TD]
[TD="class: fOne"]Sustitución
[/TD]
[TD="class: fOne"]180 ml
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
34 - Frenos
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Nivel de líquido de frenos delante
[/TD]
[TD="class: fOne"]Depósito de líquido de frenos en posición horizontal
[/TD]
[TD="class: fOne"]El nivel de líquido de frenos no debe estar por debajo de la marca MIN.
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
Aceite hidráulico (Líquido de frenos, DOT4)
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Nivel de líquido de frenos detrás
[/TD]
[/TD]
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
3411 - Freno de la rueda delantera
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Espesor del disco de freno delantero
[/TD]
[TD="class: fOne"]Pieza nueva
[/TD]
[TD="class: fOne"]4,5 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Límite de desgaste
[/TD]
[TD="class: fOne"]4 mm
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Límite de desgaste de la pastilla de freno delantero
[/TD]
[TD="class: fOne"]Sólo forro de fricción sin placa portante. Las marcas de desgaste (ranuras) deben ser claramente visibles.
[/TD]
[TD="class: fOne"]1,0 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Alabeo lateral del disco de freno delantero
[/TD]
[TD="class: fOne"]En el diámetro exterior
[/TD]
[TD="class: fOne"]máx. 0,15 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
3421 - Freno de la rueda trasera
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Límite de desgaste de la pastilla de freno trasero
[/TD]
[TD="class: fOne"]Solo forro de fricción sin placa portante. El disco de freno no debe poder verse a través del orificio de la pastilla interior del freno.
[/TD]
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Grosor del disco de freno trasero
[/TD]
[/TD]
[TD="class: fOne"]5 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Indicador de desgaste de la pastilla de freno
[/TD]
[TD="class: fOne"]3 anillos visibles
[/TD]
[TD="class: fOne"]Grosor de las pastillas de freno: 75 % mín.
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]2 anillos visibles
[/TD]
[TD="class: fOne"]Grosor de las pastillas de freno: 50 % mín.
[/TD]
[/TR]
[TR]
[TD="class: fOne"]1 anillo visible
[/TD]
[TD="class: fOne"]Grosor de las pastillas de freno: 50-25 %
[/TD]
[/TR]
[TR]
[TD="class: fOne"]No se ve ningún anillo
[/TD]
[TD="class: fOne"]Sustituir la pastilla de freno
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Alabeo lateral del disco de freno trasero
[/TD]
[TD="class: fOne"]en el diámetro exterior, componentes refrigerados
[/TD]
[TD="class: fOne"]máx. 0,35 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
3630 - Ruedas de la motocicleta
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Desequilibrio admisible de la rueda delantera
[/TD]
[TD="class: fOne"]máx. 5 g
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Desequilibrio admisible de la rueda trasera
[/TD]
[TD="class: fOne"]máx. 25 g
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Peso de equilibrado admisible de la rueda trasera
[/TD]
[TD="class: fOne"]máx. 80 g
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Peso de equilibrado admisible de la rueda delantera
[/TD]
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
3632 - Neumáticos
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Presión de inflado del neumático delantero
[/TD]
[TD="class: fOne"]Modo en solitario, con los neumáticos fríos
[/TD]
[TD="class: fOne"]2,2 bar
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Funcionamiento con acompañante o carga, con los neumáticos fríos
[/TD]
[TD="class: fOne"]2,5 bar
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Profundidad del perfil de los neumáticos delantero y trasero
[/TD]
[TD="class: fOne"]Solo para Alemania
[/TD]
[TD="class: fOne"]mín. 1,6 mm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Fuera de Alemania
[/TD]
[TD="class: fOne"]Prescripción legal específica del país
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Presión de inflado del neumático trasero
[/TD]
[/TD]
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[/TD]
[TD="class: fOne"]2,9 bar
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Presión de comprobación de la válvula de la rueda
[/TD]
[TD="class: fOne"]4 bar
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
6312 - Faro
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Distancia entre el faro y la superficie de proyección
Para ajuste del faro
[/TD]
[TD="class: fOne"]10 m
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Distancia del límite claro/oscuro a la altura del centro del faro
[/TD]
[TD="class: fOne"]Tren de rodaje en ajuste básico y vehículo cargado con 85 kg
[/TD]
[TD="class: fOne"]15 cm
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[/TABLE]
[TR]
11 11 - Bloque motor
[/TD]
[/TR]
[/TABLE]
[TR]
Tapón roscado de vaciado de aceite en el cárter del cigüeñal
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M16 × 1,5
[/TD]
[TD="class: fOne"]32 Nm
[/TD]
[TD="class: fOne"][/TD]
[/TR]
[/TABLE]
[TR]
11 12 - Culata con tapa
[/TD]
[/TR]
[/TABLE]
[TR]
Tapa de la culata en la culata
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M6 x 72
[/TD]
[TD="class: fOne"]
apretar en cruz
[/TD]
[/TR]
[TR]
[TD="class: fOne"]10 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Culata en cilindro (apriete posterior)
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Tuerca de tirante, M10
[/TD]
[TD="class: fOne"]
Apretar las tuercas en cruz consecutivamente y apretarlas de nuevo
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Apriete previo, 20 Nm
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Apriete final, 180°
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M10 x 90
[/TD]
[TD="class: fOne"]
Soltar el tornillo y apretarlo de nuevo
[/TD]
[/TR]
[TR]
[TD="class: fOne"]40 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
11 33 - Basculante / biela de arrastre con cojinete
[/TD]
[/TR]
[/TABLE]
[TR]
Contratuerca del tornillo de reglaje de la válvula
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M6 x 0,5
[/TD]
[TD="class: fOne"]8 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Puente de alojamiento del soporte de los elementos de distribución
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 x 30
[/TD]
[TD="class: fOne"]18 Nm
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 × 40
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Apriete inicial, 90°
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Apriete final, 90°
[/TD]
[/TR]
[/TABLE]
[TR]
11 42 - Filtro de aceite y conducciones
[/TD]
[/TR]
[/TABLE]
[TR]
Filtro de aceite en el cárter del cigüeñal
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Anillo de obturación humedecido con aceite de motor
[/TD]
[TD="class: fOne"]11 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
12 12 - Equipo de encendido, bujías
[/TD]
[/TR]
[/TABLE]
[TR]
Bujía principal a la culata
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Bosch YR5LDE, M12 x 1,25
[/TD]
[TD="class: fOne"]Primer apriete y apriete reiterado, 23 Nm
[/TD]
[/TR]
[TR]
[TD="class: fOne"]NGK DCPR8EKC, M12 x 1,25
[/TD]
[TD="class: fOne"]Primer apriete y apriete reiterado, 20 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Bujía secundaria a la culata
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
12 13 - Bobina de encendido
[/TD]
[/TR]
[/TABLE]
[TR]
Cubierta de la bobina de la bujía secundaria a la culata
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M6 x 12
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
16 11 - Depósito de combustible con tubo de llenado
[/TD]
[/TR]
[/TABLE]
[TR]
Depósito de combustible al chasis
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 x 45
[/TD]
[TD="class: fOne"]22 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
18 12 - Silencioso
[/TD]
[/TR]
[/TABLE]
[TR]
Silenciador a semichasis trasero
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 × 35
[/TD]
[TD="class: fOne"]19 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Abrazadera en el silencioso y el colector de escape
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M10 x 1,5
[/TD]
[TD="class: fOne"]55 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
21 52 - Accionamiento de embrague (hidráulica)
[/TD]
[/TR]
[/TABLE]
[TR]
Cilindro receptor del embrague al cambio
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M6 x 18
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
Conducción del embrague a la maneta del embrague
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Tornillo hueco
[/TD]
[TD="class: fOne"]24 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Tubería del sistema hidráulico del embrague al cilindro receptor del embrague
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
Tapón roscado de llenado de aceite del cambio
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M14 x 1,5
[/TD]
[TD="class: fOne"]30 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Tapón roscado de vaciado para aceite del cambio
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M18 x 1,5
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
31 42 - Horquilla telescópica
[/TD]
[/TR]
[/TABLE]
[TR]
Tornillo de apriete (eje enchufable) en el tubo deslizante
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 x 35
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
32 72 - Maneta
[/TD]
[/TR]
[/TABLE]
[TR]
Conjunto del puño al manillar
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M5 x 20
[/TD]
[TD="class: fOne"]5 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
33 11 - Carcasa de la propulsión de la rueda trasera con tapa
[/TD]
[/TR]
[/TABLE]
[TR]
Tapón roscado de vaciado de aceite en el engranaje angular
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M12 x 1
[/TD]
[TD="class: fOne"]20 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Tapón roscado de llenado de aceite en carcasa del accionamiento de la rueda trasera
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M12 x 1,5
con anillo de obturación 12 x 16
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
33 17 - Suspensión de la propulsión trasera
[/TD]
[/TR]
[/TABLE]
[TR]
Tirante Paralever a la propulsión de la rueda trasera
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M10 x 55 - 10.9, Sustituir la tuerca
Fijador de tornillos (mecánico)
[/TD]
[TD="class: fOne"]42 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
34 11 - Freno de la rueda delantera
[/TD]
[/TR]
[/TABLE]
[TR]
Disco de freno a la rueda delantera
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Tornillo de cabeza plana para el paquete de remache, M8 x 27 - 10.9, Cambiar el tornillo
Fijador de tornillos (microencapsulado)
[/TD]
[TD="class: fOne"]
apretar de forma progresiva en cruz
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
[TR]
Pinza de freno en el tubo deslizante
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 - 10.9
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
Tornillo de purga de aire de la pinza de freno delantero
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M7 x 1
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
Tornillo de purga de aire del conjunto de freno
[/TD]
[/TR]
[TR]
[/TD]
[TD="class: fOne"]2 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
34 21 - Freno de la rueda trasera
[/TD]
[/TR]
[/TABLE]
[TR]
Pinza del freno en el engranaje angular
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 x 25
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
[TD="class: fOne"]
Tornillo de purga de aire de la pinza de freno trasera
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
Disco de freno al portarruedas
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M8 x 15.5, Cambiar el tornillo
[/TD]
[TD="class: fOne"]
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Apriete inicial, 12 Nm
[/TD]
[/TR]
[TR]
[TD="class: fOne"]Apriete final, 30 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
34 52 - Componentes electrónicos
[/TD]
[/TR]
[/TABLE]
[TR]
Sensor del número de revoluciones a la propulsión de la rueda trasera
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M5 x 10
[/TD]
[TD="class: fOne"]4 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
36 31 - Ruedas con cojinete
[/TD]
[/TR]
[/TABLE]
[TR]
Eje insertable en su alojamiento
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M24 x 1,5
[/TD]
[TD="class: fOne"]50 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
Rueda trasera al portarruedas
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M10 x 40 x 1.25
[/TD]
[TD="class: fOne"]
apretar en cruz
[/TD]
[/TR]
[TR]
[TD="class: fOne"]60 Nm
[/TD]
[/TR]
[/TABLE]
[/TABLE]
[TR]
46 53 - Caballete lateral
[/TD]
[/TR]
[/TABLE]
[TR]
Caballete lateral al soporte del cojinete
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M10 x 1, Sustituir el tornillo
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TABLE]
[TR]
51 16 - Retrovisores, molduras, ceniceros, compartimentos portaobjetos
[/TD]
[/TR]
[/TABLE]
[TR]
Retrovisor a la pieza de apriete
[/TD]
[/TR]
[TR]
[TD="class: fOne"]M10 x 1,25 rosca a izquierdas
[/TD]
[/TD]
[/TR]
[/TABLE]
[TR]
Pieza de apriete al caballete de apriete
[/TD]
[/TR]
[TR]
[/TD]
[TD="class: fOne"]25 Nm
[/TD]
[/TR]
[/TABLE]
[TR]
63 12 - Faro
[/TD]
[/TR]
[/TABLE]
[TR]
Faro en soporte
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
