aunque er titanic se hunda los mirlos tnemos plumas pa volaaaaaaaaaaaaaaaaaa
alvata
20 Dic 2006
bueno primer post dedicado para los que la crisis lo tiene acojonao
Abierto nuevo post
zanzacabo lo bueno ahora esta la de dos hermanas pero eso ni es feria ni naaaaaaaaaaaaa
bueno voy a ver si me cabe o no me cabe ....
bueno abierto nuevo post aqui los anteriores
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1270032069
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1279124276/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1285658268/720#728
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1288715150
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1292881491/0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1296734627/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1300217834/0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1304804306/0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1308576494/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1312322094
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1311118182/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1313937940/0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1315069627
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1315831573/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1316622212/240#240
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1319136412/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1320044652/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1320780598
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1321697321
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1322330455/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1323241991/0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1323891211/0#0
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1324902809
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1325974696/137#137
http://www.bmwmotos.com/cgi-bin/yabb2.4/YaBB.pl?num=1327594020/0
http://www.bmwmotos.com/foro/showthread.php?256380-hoy-para-comer-hay-mirlo-con-papas
http://www.bmwmotos.com/foro/showth...nquito-los-pajaros-y-los-creadores-de-blojjss
http://www.bmwmotos.com/foro/showth...s-mirlos-comen-alpiste-pos-yo-se-la-he-chupao
http://www.bmwmotos.com/foro/showth...__8932__Turnigy_2200mAh_3S_20C_Lipo_Pack.html
http://www.bmwmotos.com/foro/showthread.php?429414-mirluqui-pasa-pasa-barato-barato
Ole! Post nuevo, vamos a estrenarlo….
El ultimo dia, habíamos dejado la pobre moto tal que asi.
Ahora procederemos a desmontar el sistema de carga antiguo y montar el nuevo. Lo primero, después de desmontar el carenado y antes de quitar la tapa del alternador es desconectar el negativo de la bateria para evitarnos disgusto, además es tan solo aflojar un tornillito asi pues
(notese que me he vuelto a poner los guantes negros que tanto ponen a Spinner, que esta hecho un fetichista)
Quitamos los dos tornillos de la tapa del alternador, la retiramos y nos encontr5amos con esto:
El sistema de carga de SH es casi plug & play , es decir no hay que modificar casi nada y de la instalación existente solo necesitamos un cablecito azul que va en el mazo de cables del regulador conectado a la place de diodos. Empezamos desconectando todos los cables que salen de la placa de diodos, o sea, dos de masa, el rojo que va a la batería, que en realidad va al motor de arranque (por lo cual hay que desmontar la tapa superior del motor para tener acceso) el azul que va al regulador, el mazo que va a las tres bobinas del alternador y el que va al terminal Y del alternador, quitamos un par de tuercas y voila, ya tenemos la placa fuera
A continuación desconectamos el conector del regulador, quitamos dos tornillos y fuera :
Vamos ahora por el alternador, desconectamos los conectores de las escobillas (cables marron y negro), los encintamos y los metemos en algún hueco que no estorben. A continuación y antes de sacar el alternador, metemos un cartón entre las escobillas del alternador y las pistas del rotor, para que al extraer el alternador, las escobillas no se enganchen y se rompan o dañen el portaescobillas
Aflojamos los trtes tornillos y con cuidado hacemos palanca en los bordes con un mango de plástico o madera parra no marcar el alternador, y tras breves instantes lo tendremos en la mano
Para sacar el rotor, necesitamos un tornillo especial o en su defecto un trozo de varilla de acero de buena calidad de 55 mm de longitud por 6 mm de diámetro, aquí podeis ver el tornillo para desmontar el rotor junto al original
Para desmontar el rotor metemos una marcha para que el cigüeñal no gire y tampoco esta de mas presionar el pedal de freno trasero, metemos el tornillo especifico y depues de hacer algo de fuerza el rotor salta
Limpiamos un poco, y ya tenemos todo listo para montar
En primer lugar presentamos el alternador y lo centramos
Pasamos el mazo de cables (tres cables) que sale de la trasera del estator hacia el lugar donde ira el controlador, que es el mimo donde se hallaba el regulador original, o sea aquí:
Una vez que comprobamos que el estator esta centrado y que los cables tiene el largo adecuado, quitamos los tornillos (uno cada vez para que no se nos mueva el estator) les untamos fijador de rosca (yo he usado loctite 247, que no es muy fuerte y se puede quitar sin tener que calentar ni hacer cosas raras) y los volvemos a colocar
Colocamos el rotor (ojo con los imanes que deben ser de neodimio o algo asi, por que fue acercar el rotor a su posición y salió despedido que si me pilla un dedo, lo pierdo)
Ponemos el tornillo con su correspondiente arandela (yo he usado una grower, pero el kit traia una normal), ajustamos la apretometrica a 30 nm
Y con una marcha metida y el freno trasero pisado le damos su par de apriete adecuado.
Lo siguiente es colocar el controlador y el cableado restante, que son tres cables, el positivo que va al motor de arranque, el de masa, que yo he cogido a uno de los tornillos donde hacia masa la placa de diodos (para no complicarme la vida) y el que va al testigo de carga que no es otro que el cable azul que deconectamos de la trasera de la placa de diodos
Aquí el lugar donde va conectada la masa
Una de las partes mas coñazos es pasar todos los cable por la junta de goma de la parte alta del motor, en primer lugar ahora hay mas cables que antes y por tanto hay que recortar un pco el pasacable y luego conseguir que se quede en su sitio, aquí teneis en primer plano al muy maldito pasacables
Con esto hemos finalizado la instalación, y nos ha quedado todo asi de recogido
Cerramos la tapa, conectamos la batería y damos el contacto, el testigo de carga se enciende, lo cual es buena señal
Arrancamos y ….
A poco mas de 500 vueltas el testigo se apaga!
Brindemos por ello (con guantes y todo)
Por ahora, solo la he probado por ciudad (el peor entorno para el sistema de carga) y las conclusiones preliminares son que el sistema empieza a cargar desde poco mas de 600 rpm y ya a 2000 rpm da casi 14V, por lo cual la moto carga durante los trayectos cortos por ciudad.
Un saludote a todos.
He estado a punto de llamarte ayer por la tarde(no tendrias cobertura por estar trabajando en el zulo)he estado en tu terra unos dias pero......ya te contaré ha sido mu duro y mu blanco, enhorabuena por el montaje
Quien ha pagado el rescate a la banda del rulo?
Por cierto, necesito pintar........me las uñas
Nacho que lo sepas estas rodeado, tenemos rutita el Domingo por la mañana,,,,,,no tienes escapatoria,,,,,a comer a casa,,,,yo me encargo de ti, to la mañana contigo pa que no te despistes jejejej,....................... veo blanco por tos laos
Por Dios...!!! Que lo suban a tutoriales al tío de los guantes de nazareno...!!! jajajajaj
En serio, chapeau...!!! Gracias, Enrique!
Y gracias Tato por el guiño del título del post... ;)
¿Rutita el domingooooooo? ¡¡Cuenta Robe Cuenta!! A lo mejor puedo ir y tó ;)
Este Spiri es la lesche ,despues dice que no se entera de ná,como el der peine,este Domingo hemos quedao Los Mirlos en Los Barriles a las 9,30 pa darnos un vuelo serrano. Er niño de Huerva tambien puede acudir,,,,,!!No puede alegar falta de motos!!!
mak como se nota que la crisis no ha llegado a tu sector y menos a ti .... como zéntere tu mujer lo que te ha costao te capa .....
ayer a roberto le tuvimos que cortar la broma porque se estaba poniendo azul acojonao al entregarle la analitica
Joder Tato es que en un año sin cojer las motos se ahorra una pasta en gasolina...
Curro Los Mirlos fueron bien informados pero de pico por un servidor, el folleto impreso se quedó en Sevilla y yo vine a los Barriles directo desde Zahara, este Domingo que tenemos UNA SALIDA, aunque solo iremos unos cuantos, se los entregar'e
Mak Para que te des cuenta de a lo que puede llegar una mente envidiosa y mezquina capaz de falsificar una analitica para acojonar a un amigo
Quillo es que desde que no hay crónica de los miércoles (espero que sea porque el cronista oficial esta polinizando arduamente, por que sino no tiene perdón de dios) los mirlos de Allende el Guadalquivir no nos enteramos de na.
De quien era la misiva? Para que te hiciste una analítica ? Como se te ocurrió ponerte en manos del doctor inquieto (tienes mas valor que José Tomás)? En fin ya me contareis cuando nos veamos
El cronista está fatá de lo suyo, nada mas que hace buscar excusas pa no "p...........ar" los que tienen el nick que empieza con s lo llevan fatal , es mu dificil sacarles crias,no es que no valgan,,,,,,,,,es que no lo intentan.......
La carta era de Curroalb referente a Halowen que este año va a ser la releche. Ya está er sentauro arreglando permisos.
Lo de la analitica es un acto heroico que he afrontado,lo que ha pasao es que cuando estaba ordenando "los analise" lo llamó la suegra y hubo un cierto revuelo
Hola Roberto
¿LLevaste la misiva ayer a los Barriles?
Currooooooooooo... Holaaaaaaaaaaaaa...!!! Tío, perdona... anoche cuando subí a casa vi que me habías llamado, y SpBit también me había llamado dos veces... lo siento...
Ayer, a eso de las nueve, se me ocurrió cambiar la lámpara de posición y la luz corta a la K75RT... DOS HORAS Y MEDIA... liado en el parking de mi casa... DOS PUTAS HORAS Y MEDIA...!!! Como para que me contraten de mecánico en Ferrari... jaaaaaaaaaaaaaajajajajaja...!!!
Voy a entrar en el foro de las K y les voy a decir a los que tengan una RT que cuando se les funda la bombilla que tiren la moto... que no merece la pena arreglarla... que se compren otra... Uf... Vaya majao que tiene la cosa...!!! jajajajajaja
Así que subí a casa pasadas las once y media de la noche cuando vi vuestras llamadas. Lo siento...
Aprovecho para poner esta foto con la que me he tropezado hoy... que cosa más bonita de moto, por Dios!
Vaya en el follón que me he metido....
Todo sea por buscar voltios perdidos
¡¡Yolovisto Yolovisto!!! Estabe en el cable. ...... ¡¡Vaya!! Ya se ha ido
Muchas gracias Roberto, pero en mi segunda tierra, estamos de Rocio. Seguramente, iremos el sábado y el domingo a dar alguna vuelta, a ver los amigos.
A pasarlo bien, y cuidadin.
La cosa está cada vez peor.........................me acabo de quedar a cuadros,,,,,,,,,,,,¿El Brillitos en el Rocio? Tan mala está la cosa que solo te queda........el polvo del camino:D:D:D Yo es que me meo toa, irás por alli con un monton de trapos, plumeros y un matamoscas:D:D Perdonamé Juan, pero es que no te imagino en el Rocio,tu tan limpito, tan pulcro,tan brillante en suma y mezclao con los alerones cantosos que por allí se huelen :D:D
Yo si que me meo Toa, la madre que parioooooo, Manoli se muere de risa.
Que no Robe, que no. Que pa mis cosas soy muy cuidadoso, pero pa mi persona soy un desastre, te lo aseguro.
Pero te cofieso que el Rocio no me gusta en absoluto. Peroooo habrá que aguantar el chaparrón, pues.... la frase de marras " Aqui na más, tus amigos, los mios, unnnn, ni en fotos,eres un egoista. Ya, ya,ya, haber si me dices algo de alguna rutita, que te vas a ir con Rita la cantaora..............bla bla bla..... diálogo de besugos glu, glu glu........
Yo tengo en la entrada de mi casa una placa que refleja mi filosofia de vida ........LO QUE DIGA MI MUJER...esto es peloteo por si se mete en foro
Asi megusta, que seais obedientes y buenos chicos, se os recompensara,jajajajaja.
Jalbarrrrraaaaaaaaaaaaaaaa que el Domingo tenemos rutita, mañana no el Domingo, a las 9,30 en Los Barriles
Estos son unos que me he comprado. Los míos están puestos
sigo perdiendo sae por la botella derecha, otros pantalones jodidos. Me he fijado y la botella tiene como un chinazo o un golpecito.
Er chinaso,lo limpias bien, lo desengrasas y cuando esté todo limpito le vas dando Cianocrilato (Loctite o de los chinos) hasta que se rellene o un poco mas y despues con lija finisima y aceite Dar cera pulir cera hasta que no se note, tambien se puede llevar la barra a recromar en Almeria (aun no me he enterado lo que vale pero creo que barato) y tambien en la Avenida de Jerez antes de los Barriles a la derecha tambien te pueden cambiar el pantalon (por detrás)
yo si no fuera porque me pillais mu lejos mañana domingo me iría a dar una vuelta con los mirlos,eso sí,iría subido en otra minipimer como la de spinner.saludos y a ver si nos vemos pronto.
Tu puedes venir con nosotros aunque sea andando:D a ver Diego se deja de cachondeos y nos vemos en el Burgo II, Un Abrazo Bultaquero,,,,,que arte con lo del Angel de la Guarda y la Frontera-370,,,,,,A mi el mio me esperaba den las gasolineras
Pajaro en el nido. Siesta hasta lo menos las siete. A ver si pala próxims toooos los pajaros volamos pal mismo lao, que si no eto va siempre a sé un descontrol
Yo en el nido pero cabreado,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,creo que no se debe desaparecer sin mas, se habla y ya está,todo el mundo tiene obligaciones y polinizaciones pendientes,pero algun dia un pajaro se quedará tirao y nadie sabrá nada. No me deis estos disgustos que me habeis dejado sin ganas de tomar ni una carveza y a Alejandro le ha pasado lo mismo....
A las mariconas que vuelven por autopista,,,,,a ver si aumentais el ritmo que los de la general salimos por delante:D:D
Mirlito en er nido, tube que parar , es me estaba volando la bufada, y me fui por el almillo pa mi casa, lo siento podiamos haber toma do alguna birrita.
Mirlito en er nido, Rober tube que parar, se me estaba volando la pu......ñetera bufanda, lo siento , podiamos haber tomado alguna birra en los Barriles.
En definitiva, veo que nada cambia, Nacho y yo no vamos por problemas técnicos y nocturnos, Resnian hace como que va pero ya ni siquiera va al desayuno para luego volverse a casa, Alvata y Jalbarra haciendo su propia ruta porque no les sale de los webs ir pendientes y a la vuelta cada uno a lo suyo por su lado. Está claro que para tomar cervezas somos los mejores pero para salir a carretera somos un puto desastre, y sinceramente, eso no me mola nada... :(
No hombre tampoco es eso,somos un grupo peculiar hasta en las salidas,,,,se improvisa mucho ,quedamos en una venta que esta cerrada y algunos quieren ver la F-1 y pasa lo que pasa y despues estan las anecdotas si estamos en un sitio superdespejado unas 10-12 motos y un grupo de tios saltando y haciendo gestos ........................como pueden pasar 3 tios 3 y no vernos:D:D
Hago copia-pega del otro foro (que lío...)
Que bien me lo he pasado hoy !!! Que buena organización !! Íbamos todos por estatura, como los hemanos Dalton, Que despliegueee , ji, ji, ji..
:face: :cyclops: :twisted: :no: :bounce: :drunken: :queen: :albino:
Estoy deseando hacer un viajecito un poco más largo para ver como llegamos
:beers: :beers:
que bien lo pasamso he estado molido to er dia , menos mal que no vino gente impresentables de los que dicen que van pero no van , yo tire por autopista pues era lo que habia comentado y tenia mucha prisa al llegar ala rotonda os pite para indicaroslo , lo de jalbarra es un clasico yaaaaaaaaaaaaaa.
habra que repetir
Lo cachondo fué que ibamos por la general y te ibamos viendo a ti por la autovia y despues te dejamos atrás jejeje,pero te ví toda la mañana disfrutando,,,en cuanto te quites el escapulario todo cambiará jeje
Por cierto, que no he dicho ná.... La Sentaura, espectacular como siempre :rolleyes2:
Una verdad como un templo,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, las demas una porqueria ........algunas volvieron en la grua,otras la tiramos por los barrancos,y la que quedó la quemamos........................................................:D eaa potequieyyá Sentauro trompetilla
:D
Adolfo, tu ni cuenta. Envidia de no tener una moto que vaya bien................................
La RS no hay quien la ponga a punto, y la GS sin pata de arranque .......................................
:D
Que si tengounafugilla (eeeh Robe?) en la GS que no se la puedoKitáymetieneloKoYa .... que si "se me abren los cierres" (eeeeh Robe?) de la GSen cuantocoge un bache, que si no voy poque "mese" salen los aseites, que si el cable no da corriente ....
Una de dos, o vuestras motos son un mojón o sois los peores mecánicos "der mundo mundiá" :D
PD: Verá la Ke me vá a dá
Es que no hay dinero pató,,nos lo hemos gastao en .................CASCOS
Que tas pasao la noche esperando que salten la reja ,,,,pa que termine ER ROCIO
:rolleyes2: Uy uy uy ...
Dice el refrán, que "el que se pica, ajos come"...
Yo no digo ná...
Y por favor ... Esas voces ... No me lo esperaba yo de una persona como usted ... (¿Sabrá piKaooooo?) :D
Pues visto lo visto,..sera en cascos ....de botellines
